steering coupler replacement (how to)
There's a small pin up near the seal retainer that needs to be driven in, it's an 1/8" diameter (I think) and its on one of the flat sides of the coupler.
Thanks for that illustration Daliant! The small pin your talking about won't come out as easy as the roll pin. I'm guessing it needs more force to pop out?
Also, I was gonna buy the seal and cover from Steer and Gear but wasn't sure if you knew of another place?
Are you trying to stick to the factory setup? I switched to something like this and it works great!
http://www.wellerracing.com/Sweet-Mfg-Steering-U-Joint-34-Smooth-TO-34-36-Spline_p_2111.html
x2, Worked great for me, Looks clean and no slop what so ever.
Mike
Man I love the looks of that new style coupler. Biggest issue I have now is the rubber and stock coupler are too close to my Dougs headers. I have power steering so the box is a bit big. This new style coupler looks like it eliminates all that garbage. I'm going to go with that! Thanks!!
Wise choice. The bottle cap type crimp on the top of the original box coupling is a real pain to get right anyway.
Thanks again Meridian, Issue I'm having now is I can't find the small pin to knock out. Do you or anyone know if they had the small pin in 73?
Anybody know which of these (size/spline) I would use on a 69 Dart (pwr steering)? so I could order without having to take my column apart until I need to? Thanks...
The pin is inside the coupler, you need to disconnect the coupler from the steering box then slide off the coupler and inside with all the grease is the pin. knock the pin out, which isnt easy. use that hole for the bolt location on the new joint setup. Sorry if you did this but you will see it once taken apart, cant miss it.
Thanks
this is the one I bought for my Dart with a power steering unit, I switched to a manual unit and its the same spline as well. Also I just checked my old power steering unit and its a 3/4 36 spline.
http://www.bryke.com/310-236/Steering+U+Joint.html
Thanks
I had to stick my finger inside the coupler to find the pin. On the outside it was hidden by all the dirt and grease. Ended up using a 3/32" pin punch and she came right out. Called Bryke racing and ordered that 3/4 - 36 spline U joint. Guy on the phone suggested I weld the non-spline side to the shaft because there was no hole. I'm guessing you drilled a hole? Thanks again!!
For those who like this idea I have found the place I bought mine at which was:
http://www.bryke.com/steering_accessories.html
They are cheaper then what I pointed out earlier (wellerracing was just for conversation purposes)...just check your shaft and spline count and you will never look back!
ZOMG!!!
This is just what I was looking for. Thx for the heads up!
I just noticed this thread. I got my u-joint coupler from Flaming River. Nice piece, but it requires sawing off the shaft and drilling a cross hole.
Yes I drilled a hole to accept the coupler. I was going to weld mine but I wanted to be able to remove if needed.
anyone what size we would need for this application to a manual box?
Yes it should I switched to a manual and the spline was the same..but that was for mine. Always double check your application.
Smart move Meridian, I'm gonna drill a hole just in case I need to pull if off in the future. I almost went with Flaming River but their price was over $20 more than Bryke. By the looks of it this mod is so much cleaner than stock and I'll have tons more clearance around my headers. Win Win
Got this feedback from mcnoople from a related thread
(http://www.forabodiesonly.com/mopar/showthread.php?t=221346)
and it opens a whole new discussion:
[FONT=&quot]
[/FONT]I don't think I would be comfortable with the u-joint style coupler posted. Without any method allowing for the coupler to slide up and down it looks like it would cause binding everytime the the u-joint rotated. I would like to see a company make a coupler similar to what modern cars use for their steering intermediate shafts. Here is a link to a picture of what I mean.
And for those that have problems with factory style coupler seals, there was a factory designed bail clamp that was introduced that would clamp the coupler seal down tight and prevent it from coming off.
http://www.google.com/imgres?imgurl...UHUZi_OOXkygGBw4DADw&ved=0CDsQ9QEwAw&dur=8861
Would appreciate comments and/or opinions.
______________________________________________________________
I suppose anything can happen but not sure on the binding issue, these joints are nothing new been around for years, so speaking from first hand use I have had mine for many years with no issues.
Yeah I highly doubt the binding issue. The people at Bryke make those couplers specifically for their late model dirt track cars which probably see a whole lot more steering action than a street car ever would. Hence is why they weld their couplers to the shafts.
