68Dartvader
Anyone seen this before if so how do i remove it to take it to a click shop
Off a 67 dart
Off a 67 dart
Push to blow. The horn ring is held with screws beneath the center. The center has steel latching fingers. Pushing on the center wouldn't effect them. Just twist to unlatch.Dont you have to push in on the horn ring before you twist counter clockwise?
I havent taken my horn ring off but that is how all other cars i have had in tbe past were
This fancy horn ring shown ( with dust collecting grooves in it ) is more common to b-c- bodies but is seen in a few a-bodies. Our very first 67 notch had the same part. I still have it here.
I muddied the waters a bit when I was talking horn ring, I was talking the entire horn assy, the center and outer large diameter ring on spokes. in many Fords I have had there is a plastic part that holds the horn assy to the steering wheel and if you just twisted it would break the plastic ears off.Push to blow. The horn ring is held with screws beneath the center. The center has steel latching fingers. Pushing on the center wouldn't effect them. Just twist to unlatch.
