AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 25,116
- Reaction score
- 12,472
With the 268* cam I think you would need to get the Scr down to under 10/1
A 408 has a swept of 835.7cc so a 10/1 Scr will need 835.7/9.0 =92.86 minimum total chamber volume.
Anyone else see a problem here?
92.86 less (62heads + 8.9 gasket) = 21.96 in the dome and deck clearance .
And you don't want to take much off the Q pad, so I think we're looking at a step-D cup, aren't we?
I think OP needs different pistons,(Probably the cheapest solution)
or iron open chamber heads with a lot more volume,
or aluminum open chamber heads.
And some custom fitment
I entered 64* for the ICA, of the 268*/110 cam in at 106. This for iron headsand pump gas.
Static compression ratio of 10:1.
Effective stroke is 3.15 inches.
Your dynamic compression ratio is 8.09:1 .
Your dynamic cranking pressure is 162.22 PSI.
V/P (Volume to Pressure Index) is 156
With aluminum heads you could probably run close to 9.0Dcr on 91gas.
So that gets us this,still the 64* ICA
Static compression ratio of 11:1.
Your dynamic compression ratio is 8.88:1 .
Your dynamic cranking pressure is 182.96 PSI.
V/P (Volume to Pressure Index) is 176
And to run 11/1 we need a new minimum chamber size of 835.7/10= 83.57cc
Assuming 63 for the heads and still 8.9 for the gasket, now we are down to 11.67 in the deck/dome.
But get a load of that 176VP. You could blow a lot of that off and get a bigger cam, more suited to the 408.
And the 340 Eddies might save a teardown, depending on the current pop-up.
So I worked this out with a 284 cam and an ICA of 68* and with the 65cc Eddies PN 60179 complete.
Static compression ratio of 10.5:1.
Effective stroke is 3.04 inches.
Your dynamic compression ratio is 8.22:1 .
Your dynamic cranking pressure is 165.61 PSI.
V/P (Volume to Pressure Index) is 154
So this is about the lowest Dcr I'd run. This should burn 87E10.
Now back to the total chamber volume. 835.7/9.5= 88cc ,And we have 65+8.9=73.9 so that allows up to 14.1 in the dome/deck.
So is it doable yet?
I guess the next step is to measure the dome volume and the pop-up height.
If you have to machine the pistons no matter what, the following would be a better target with that 284 cam, and aluminumheads;
Your dynamic compression ratio is 8.60:1 .
Your dynamic cranking pressure is 175.57 PSI.
V/P (Volume to Pressure Index) is 163
The VP is climbing again, so you could probable get away with a low-stall TC and hiway gears. But the cruise rpm should really be a little higher for that 284 cam, like maybe minimum 2400 I'm guessing, to get the best fuel-mileage,lol. So that points to minimum 3.23s at 65mph.
