Stop in for a cup of coffee
@halifaxhops ,i’m in the same boot...
Everybody must be out workin on their cars..
I couldnt go any farther, neck is givng me trouble.
Got 2/3 of inner wheel tub patched. The proceeded to stick my pick hammer through the trunk extension. :BangHead:
Somethin looked funky under the filler..
Wish there was a good answer for that.
Been there.
Was. Just got back.:)
Open rotors in both roundbacks.:(
Diodes seem OK.:) at least they so seem
Stator is bad in the square back.
All three seem to be missing the grease seal. Need to check the parts books.
New plan. Remove the Tuffstuff squareback and install the 70-71 roundback for now. Ironically its the one case with the most collectors value.
It could use a bearing but I'm afraid to open it since it works without complaint.
Then open up then tuffstuff squareback and see if I can figure out why its a schreechy whiner.
I looked at the second torpedo heater today and it is getting spark, the compressor is working, but is at 5 psi instead of 4 like the specs say...
It seems that it's not getting fuel... The air and fuel hoses are very dry rotted and cracked, so I will have to get new ones and change the fuel filter and see how it goes after that...
