Stop in for a cup of coffee
PS
1 Erica Enders 6.528
2 Bo Butner 6.53
3 Rodger Brogdon 6.543
4 Jeg Coughlin Jr. 6.544
5 Deric Kramer 6.546
6 Jason Line 6.549
7 Greg Anderson 6.553
8 Kenny Delco 6.554
9 Alex Laughlin 6.556
10 Chris McGaha 6.563
11 Matt Hartford 6.578
12 Fernando Cuadra 6.58
13 Steve Graham 6.623
14 Alan Prusiensky 6.648
15 Jeffrey Isbell 6.664
16 Joey Grose 6.685
17 Shane Tucker 6.715
18 Val Smeland 12.089
Erica is HOT
You open each end of the can and then use the back of a big wooden spoon to push it out. Then slice and and enjoy. Good hot or cold and yummy toasted! It’s soft and moist with a slightly sweet molasses flavor. Kinda like a dense muffin.
You said something on here about it a couple years ago and I tried it. Good stuff :thumbsup:. I don't think I actually used it as bread. I like it with a little butter. Molasses muffin- great for breakfast with a cup of coffee. Have had it a few times since. Giant sells it for $3 and change per can.
Because it has such a long shelf life, it is hugely popular with survivalists. Like most canned goods, it is still edible at twice the printed shelf life easily. I like having it in stock since even if there is a power outage or a big winter snow storm, I always have fresh bread on hand to make sandwiches or to go with soup, etc.
A case of raisin brown bread, big jar of crunchy peanut butter, and I'm good for a few days.
Can someone educate me on Big Block crank shaft pulleys? I froze in sub zero wind chills to search out some pulleys. I got 2 water pump pulleys and 1 crank pulley but it appears it has 1 set of close holes for the bolt pattern. Is there a difference between steel crank pulleys and the cast crank pulleys like mine?
All the same..
Should all be the same. Only thing I’ve ever seen as a difference is how many groves it has based on PS, AC etc
Thanks guys. I checked every set of holes while looking straight at it and there us always 1 set of holes off. The grooves will line up perfect if it would bolt on. Being that it located hub centrically, could I just open up the off hole or all of them?
Are you positive is a big block pulley?
This is especially nice for the belt pulleys to line up as with the front engine plate, typically you need to add a spacer for the water pump. This set up I dont.
Not 100% as it was a junkyard and laying loose, but was laying in a 1967 Newport big block car so I assumed I guess...do the small blocks have a set of close holes for specific orientation?
No reason you cannot just make to fit, but the question is why you need to. Might be from a industrial engine, but not sure even then if different.
Only fits one way.
