Stop in for a cup of coffee
The other other white meat.
“It's tasty, it's not as gamey as rabbit, it's nice white meat. It's good to cook down slowly and make stews from and ragus for lasagne."
A true conservationist.
“I also enjoy shooting, I shoot quite a lot of greys so it make sense to put it on the menu - if we shoot them we should cook with them.”
The other other white meat. View attachment 1715287665
When I blast a squirrel with the 22.250, there's barely enough left for the ants to find, let alone cook :rofl:
Grey squirrel is really good battered and fried like chicken...
Just catching up. Went and cleaned up a driveway for my buddy’s inlaws,it was really built up with snow. Its wider now and more room to turn around.
Then had to go get a tractor started for a friend.
Got front brakes on the Neon. Rotors look good and calipers are fully functional. I pulled one back wheel. Drums are rusty as heck and a bit groovy. But shoes are not too bad are functional. E brake cable moves, but ain't doing much if anything.. So will need to do something with that.
Also worked on window washer.. Pump was in sideways and would not seal. Cleaned the grommet and coated inside and out with o-ring lube and it seals now when turned up where it belongs.. Had to re-route the wire and tube to attach it with pump in correct orientation. Will need to do something with that yet, but it works. It's cold out. I'm done.
