Stop in for a cup of coffee
Wow, I am impressed. It is still hooked up. It is the part to put in the values that I need. That is worth a case of beer whenever we meet.
I assume you are going to be heating and dehumidifying? Approximately what temp and % RH do you want it to turn things on and off? You can adjust later, but I can plug your numbers in the instructions as a start point.
Have you powered it up? Just wondering what it reads initially. Should read temp and humidity 'right out of the box'. if so, do they appear to be accurate? (It can be calibrated)
Had a cup of coffee on the way to work this morning and almost didn't make it do the bathroom. turns out its also a laxative
Try this Mr Hops
TEMPERATURE AND HUMIDITY CONTROL INSTRUCTIONS
Display:
Upper. Temperature degrees C
Lower. Humidity %RH
AL1: temperature output
AL2: humidity output
SET KEY - selects parameter to adjust
<. Enter
V. Reduce value
^. Increase value
Parameters are divided into 2 groups. Basic and advanced.
To change basic parameters( group 1)
Press SET key to view desired parameter.
Use up and down keys to change value
Press enter key to set and advance to next parameter
To change advanced parameters( group 2)
Press and hold SET key for 3 seconds to view desired parameter.
To exit advanced parameter setup you need to hold SET key 3 seconds
If you cannot set, check LCK setting
The LCK function will limit access to calibrations(advanced)
LCK=00: All the parameters can be set up
LCK=10: Only group 1 can be set
LCK=11: no access (except LCK)
Group 1
1 TY1 Temperature mode. 0 cool. 1 heat
2 AL1 Temperature setpoint degrees C. (Output on)
3 HY1 Temperature variance. (Degrees change till output shuts off)
4 TY2 Humidity mode 0 dehumidify. 1 humidify
5 AL2 Humidity setpoint. %. Output on
6 HY2 Humidity variance. (% change to turn off)
Group 2
1 TSC Temperature calibration -100~100
2 HSC Humidity calibration. -100~100
3 OPY. NA
4 oP. NA
5 OPL. NA
6 OPH. NA
7 LCK Parameters lock
Well, I'm going to stand outside for a while, so if anybody asks, tell them that I'm outstanding.... :D
I'm putting spark plugs in a buddy's hemi truck. Man, these ones in the back are a *****. Then it needs a P/S hose and an oil change and a window regulator. Then it's Beer time.
Let me know so I can see fit to open one myself Mitch :D I see Karl is an outstanding man about now :D
Morning all. Hopefully I am going to meet a few members today! Heavy fog here, but nice and warm 36! Going to hit mid 50's
Sure is foggy! I have so many things going on in the next few weeks I just can;t get away today. Any other day maybe but Wednesdays are my big day.
Same here Hops :glasses7: Foggy and warm and at 53 degree's though :)
So are you going to meet dome members today Hops ? am am confused :toothy1:
How bout that Memike! i thougt tha he already was a staff member
I never dun this before and I am learning and enjoying challenge :glasses7:
Hopefully meet Moparmitch and ZKX14 in York Pa.
That would be great Hops :cheers: meeting members is a great thing and I hope you can :color: a great way to start the season out :color:
Morning all !! Doing some housekeeping on the computer this morning, then going to head out to Pa to meet up with some FABO members. Going to try to put myself on spot at as close to noon as I can. I have Keith's cell, so I'll call 15 min out. Ray if you want to PM me yours, I'll send mine back.
Good Morning!
That be the plan
Gotta go get some work done since I'll be taking a long lunch...
Keith
What is the name of the diner? also is it exit 21A on 83?
What time do you think? Times like this I wish I still had a cell phone but the day I retired I got rid of the electronic leash!
