Stop in for a cup of coffee
Perfect timing, I just went to see one of those after work. A 66 valiant, 2 door hardtop.
It is for sale and that is main reason the guy wanted me to look at it, thinking he might have a sure sale.
I declined, so if anyone is in the market....I know of a real clean one
A little experiment and learning practice welding exhaust tubing with oxy-acet today.
MIG was ok, but oxy-acet was easier to control and gave nicer results.
Lumpy stuff was first try. Adjusted for more flame, and was able to get smoother.
The stone guys were rocking and rolling today. Perfect weather, 70* low humidity and a light breeze. The front is becoming more refined and the back is leveled and ready for the pavers.
They moved in and compacted 30 cubic yards of fill base for the back...one wheel barrow at a time.
Here's the damage done so far. Went as expected except neighbors bees had moved into one of my trees, neither knew. They swarmed, neighbor had hoped to trap them back, don't know if that will happen. We can start to see the lake.
At $20 per sq ft all said and done, it is well worth the price to have it done right. Just the deck cost me the same as all this stone work. The increased value to the home is at least double what I paid for both in total.
Chris, i just googled t56 teardown,t40.
So its tight?
Propane torch,bet its locktited.
So its tight?
I don’t know, I can’t find a bit to fit it to find out. The t40s I have both are too loose and I’m afraid of stripping it. Was reading just now on the forums about them being t40 Plus size
Typical Dimensional & Torque Specifications of TORX Tools
For use with Internal Socket Head Type TORX Screws
View All Wiha Standard Torx Tools
Size
Inch
P to P
Metric
P to P
Maximum Torque Range
T1 .031 .81mm .02 to .03 Nm
T2 .036 .93mm .07 to .09 Nm
T3 .046 1.10mm .14 to .18 Nm
T4 .050 1.28mm .22 to .28 Nm
T5 .055" 1.42 mm .43 to .51 Nm
T6 .066" 1.70 mm .75 to .9 Nm
T7 .078" 1.99 mm 1.4 to 1.7 Nm
T8 .090" 2.31 mm 2.2 to 2.6 Nm
T9 .098" 2.50 mm 2.8 to 3.4 Nm
T10 .107" 2.74 mm 3.7 to 4.5 Nm
T15 .128" 3.27 mm 6.4 to 7.7 Nm
T20 .151" 3.86 mm 10.5 to 12.7 Nm
T25 .173" 4.43 mm 15.9 to 19 Nm
T27 .195" 4.99 mm 22.5 to 26.9 Nm
T30 .216" 5.52 mm 31.1 to 37.4 Nm
T40 .260" 6.65 mm 54.1 to 65.1 Nm
T45 .306" 7.82 mm 86 to 103.2 Nm
T50 .346" 8.83 mm 132 to 158 Nm
T55 .440" 11.22 mm 218 to 256 Nm
T60 .519 13.25 mm 379 to 445 Nm
T70 .610 15.51 mm 630 t0 700 Nm
T80 .690 17.54 mm 943 to 1048 Nm
T90 .784 19.92 mm 1334 to 1483 Nm
T100 .871 22.13 mm 1843 to 2048 Nm
You need to look at the fastener and see if the points are sharp or rounded. Rounded is Torx plus. They look more like a spline.
Size
Inch
P to P
Metric
P to P
Looks like this thread just got interesting again.
:poke:
Got my attention!!!!
There he was , Gone!
Goodmorning!
Had a good rain yesterday,farmers be happy i think.
Clean up my disaster from yesterday and get the week started.
Made great progress though.
As far as trailer goes, i will measure and cut down the doors/rear gates.
Dont need it in shop for that.
