Stop in for a cup of coffee
No I did not I just droed it off! No my key has to be hit hard to work. Just need to get off my *** and use the one Tim sent me, just a lot different from mine and 0400 is not the time to learn it.
Yep. Thought of that. Not jumping to swap till I at least get it cranking over better. Then check for spark...
Told you last year that thing failed in the cold. Bring it up one day we can freeze it then test it on the tester. Temp swings and new electronics don't mix to well
Or you could just swap it and see if it fires. Then go back later and figure out if the old one was bad. It’s just 2 screws and a wire connection.
Feel bad for them. Not sure who does the claim, me or them? Think I will do signature on anything over 50 for now on, even though t is not my roblem and they both said that just let me know to see if I Had more caps for them. Have to check.
You paid for the shipping but they can claim. You just have to give them the tracking info to take to the PO.
The C-130 avionics used to go nuts usually the first hard freeze. Sucked always a early morning emergency do it yesterday job in the cold. Aluminum/titanium planes are like licking a light pole.
I have done it a few times not hard at all usually. Did one with Canadian post that took a while for the refund.
That’s why when I suspected the ECU on the GTS was why it wasn’t starting I didn’t bother trying to diagnose it...I just swapped it out. Once I did, the car fired right up.
I never bothered to try to test the old one. I just disassembled it!
Tell you what watch the packages delivered if your not home have two members I sent arts to that had them taken from the front of the house. Hope their chevy guys!
And the delivery people may not be regular routes. Leave stuff wherever its convenient for them. They had a package missing at work. Delivered by Amazon. They sent a pic of where it was delivered. Was sitting by an emergency exit that used to be the smoking area.
The new ones suck as we all know. I find the old NORS/NOS ones at times and they sell fast. Steve is looking for old ones he has a mill and will be doing a GM HEI in them. There is definitely a market for them.
Of course, lower octane makes more BTU power per unit volume than higher octane does. I always run the lowest octane that doesn’t cause detonation to get the most power.
None of my cars require more than 93 octane since they are all 10.5 compression ratio or less.
I run 93 in the GTS and SRT, 89 in the 300C 5.7 Hemi and 87 in the Grand Caravan. Anything more is just more cost and less power.
Hey Dave. Have any pictures of your Christmas decorations? Or did I miss them?
Our turbo'd Buick Envision calls for premium fuel. I have never noticed any loss of power using 91 E10. I need to do a mileage test between the two.
