I will see if i can get a couple photos.
I am going to strip the 904 that I have down to the case, attach GV to it and fab it up using that. Lighter weight to move around...Wish they made a plastic small block Mopar like they do Chevy...
Street Rod Parts » Engine » Plastic Block | Street Rod HQ
They do!!! Found one!!
4033 - Chrysler 318 Short Block
4030 - Chrysler 360 w/ W-2 Heads
Expensive BUT I think I am going to spring for one......Guarantee it will get used a lot If I pass it around to guys here as needed....
He can always bring it to Carlisle and sell it......You can buy real 318 blocks cheaper than they want for the plastic one...
The farmers and the retailers don't make much. (percentage wise) The producer and wholesalers do.Just got back from the Grocery Rapists.....
Hmm cast iron. Plastic. Which is easier to get in and out? Delima....You can buy real 318 blocks cheaper than they want for the plastic one...
Hi techMeanwhile, back at the workbench...View attachment 1715645478
Those are permanent aren't they ? You welded them on, right ? I LIKE it......
The doors are the hardest part to make....And drawers...
3/8 square sticking out of door, grabbed some old sockets, machined em down so just square is left and welded to nut, welded nut to wrench. Cotter pin holds em on.Those are permanent aren't they ? You welded them on, right ? I LIKE it......
Looks good!!!!Black it is...View attachment 1715645520
