Leave it green with black scoops. And don't forget to paint the radiator support black in the front.
I was not, but I bet it will look good with the sublime...Leave it green with black scoops. And don't forget to paint the radiator support black in the front.
Your choice.I was not, but I bet it will look good with the sublime...
The entire front?Leave it green with black scoops. And don't forget to paint the radiator support black in the front.
I think you are right, would look the best.....see plans can change.... AND easier!!!Leave it green with black scoops. And don't forget to paint the radiator support black in the front.
Whatever you can see through the grilleThe entire front?
So original plan was to blackout hood and section of roof flat black. Wrap. What do you think of just the sections outside the center ridge
Good idea. I can spray it black lacquer and then the flat clear I am spraying the entire car with, can get my gun dialed in for the clear in a unobtrusive place....Whatever you can see through the grille
Well, I have the wrap.....Simulate it with something to get a better perspective
You think?The wrinkles add a little style to it also.
You think?
You know in California the oil stains on the paving needs a hazmat team called right?
Is it brown?I have a stripe I could use...
Tough....You know in California the oil stains on the paving needs a hazmat team called right?
I
Is that like what they usually have 4wds up on some awkward angle?
nope.......Is it brown?
