Stop in for a cup of coffee
The rare parts are REALLY rare over here. Large hole 340 exhaust manifolds, for instance. Or fenders for '66 Darts.
Anders that is a BIG carb. It is on a worked 440 and might be to large for your set up. Like I said I do not know small blocks well. Karl is the answer man with them..
I've seen many members put 750 carbs on their 340's and 360's...
a larger carb only helps on the top half of the rpm range, and a little bit according to desktop dyno...
If you have a good intake and cam, it can handle it.
I use the holley 600 square bore for my daily drivers and they run fine...
