Stop in for a cup of coffee
perfect ...that looks like the 68 and 9 round 340 and BB air cleaner .....that works awesome.
OMG...I LOVE that it says 383 also ....nothing against your 340s but nothing has pavement pounding belligerent launch like a big block :D:D
I e-mailed you the large version for your growing collection of Ddaddy artwork!
I think that's about what I would expect from my 360 Magnum too!
Here are my specs...
Specifications:
· Compression: 9:1
· Comp Cam 264HR short snout hydraulic roller camshaft
· 264°/274° duration (210°/220° @ 0.050)and .512 in. /.512 in. lift
  • Double roller timing chain and gears
  • Carter rotary vane electric fuel pump P4070 – 72 gph. 4-8 psi
  • Magnum swirl-port combustion chamber heads
  • High-strength stainless steel valves: 1.925" intake, 1.625" exhaust
  • Heavy-duty valve springs
  • Edelbrock RPM Air Gap Magnum aluminum dual-plane intake
  • Edelbrock 650 cfm AVS Thunder 4bbl carburetor 1806
  • Mopar Performance Parts electronic ignition kit
  • JEGS 40500 Forged Mopar Vacuum Advance Electronic Distributor
  • MSD Super Conductor 8.5mm silicone suppression spark plug wires
  • Autolite Copper 3924 spark plugs
  • Mopar cast aluminum valve covers
  • K&N High performance Air Filter
  • 11” externally balanced 2500 rpm stall torque converter
Specifications:
· Compression: 9:1
Damn near identical motors.
so you both should 1/4mile at around 12.5 sec - ish?
Sounds about right.
Watching the City Council meeting. These have turned into a goat and pony show.
Probably...if I could get it to the ground with better rear tires.
I've only got 195/70/14 BFG T/A all around right now for the "stock" look. I also have 3.91 rear gears so that makes launch traction even more challenging.
Well needless to say, Im happy about my engine. I have 2 small oil leaks I need to fix, but it should perform nicely and hopefully I dont have to pull this engine again for many many more years.
I'm right there with you. It's a nice build and fun to drive. I'm sure you will enjoy it for many years as will I with mine!
BTW, what rear gears do you have? Just curious what you have and how the drivability might compare. :)
I hear that, even with the shitty engine I had prior to this one, I still couldnt get the car to hook with street tires. My brother is going to lend me his drag radials next time I go to the track. That will make things more interesting.
Send your wife in again to straighten them all out!
LOL Kick *** dear!
you get all the good TV!
Yep we do. There are 6 guys in the back row that question every decision the council makes. Along with that are 3 councilmen that question everything that the city does or wants to do. They (the "back row boys" and the "three stooges") always complain about taxes going up but none have come up with any tax savings ideas. They just point fingers and complain. Just as a couple examples, There is one of the back row boys that owns a $258,000 property (high for our town) but complains that his taxes are too high. Forrest, another back row guy, owns 6 rental properties (slum lord) and complains also about taxes and regulations for rental owners.
Did I say goat and pony show?
