Stop in for a cup of coffee
Sounds like still air in the system.. did you bench bleed the MC?
i did. but i never get why.. seems any air in the mc would come out while bleeding, i had gravity bled the whole system and only got a little air out of it today
Step drill bit for larger hole in sheet metal? My largest bit is 1/2" need a little bigger for throttle cable.
Maybe conical grinding stone
Step drill is the way to go. You can get a cheapy at HF. They are good for maybe three holes! Blue tape the bit where you want to stop or it will pull itself in farther than you want. Lord have mercy where is Karl?
Well I have basically been on a two week whirl wind teaching rolling road show. I am whipped. Feels great to not be in front of students this morning. No way I am back reading. So apologies in advance if I am not responding to someone’s inquiry. You boys do not mess around! Lots of pages I am skipping!
Thanks..
Yeah, I've got a conical stone I'm going to work with... HF run will eat a ton of day
Just knocking around the shop today, working on parts for the Cuda. Wife and Daughter are taking me to dinner after I pick them up at 5pm... :thumbsup:
Can’t unbolt it at manifolds enough to remove just the pan?
H pipe goes between the two sides. No way to pull trans with exhaust in place. Unbolt from headers. Might be able to drop exhaust in one piece. Will try
Do I bother the wife and check the vacuum to see if it's full or just let the battery die first? :rofl: :rofl:
Relax and enjoy your time off John.
Things you should know.
It takes your food seven seconds to get from your mouth to your stomach.
One human hair can support 6.6 pounds.
The average man’s ***** is two times the length of his thumb.
Human thighbones are stronger than concrete.
A woman’s heart beats faster than a man’s.
There are about one trillion bacteria on each of your feet.
Women blink twice as often as men.
The average person’s skin weighs twice as much as the brain.
Your body uses 300 muscles to balance itself when you are standing still.
If saliva cannot dissolve something, you cannot taste it.
Women will be finished reading this by now.
Men are still busy checking their thumbs
