Stop in for a cup of coffee
Hey Scott. I sprayed yesterday also only 30 gallons. I use Credit 41 what do you use?
We have a 25 gallon ATV sprayer and also a 4 gallon backpack one. I didn't count how many times we filled those up, but is was easy 200 gallons. Using that RM43 stuff for the first time supposed to kill everything, I hope so.
Who makes that? New one on me. The 41 is a non selective herbicide. Kill even Bamboo which is amazing.
Interesting let me know. Pretty happy with what I use and way cheaper. I use 2.5 qts in 25 gallons.
Total Vegetation Killer. Kills on contact. Generic Roundup
Credit 41 Extra is a post-emergent, systemic herbicide with no soil residual activity. It is generally non-selective and gives broad-spectrum control of many annual weeds, perennial weeds, woody brush and trees. It is formulated as a water-soluble liquid. No additional surfactants, additives containing surfactant, buffering agents or pH adjusting agents are needed or recommended. It may be applied through most standard industrial or field-type sprayers after dilution and thorough mixing with water or other carriers according to label instructions.
Do not add surfactants, additives containing surfactants, buffering agents or pH adjusting agents to this product. Ammonium sulfate may be used. See the MIXING section of the label for instructions.
Time to Symptoms:
This product moves through the plant from the point of foliage contact to and into the root system. Visible effects on most annual weeds occur within 2 to 4 days, but on most perennial weeds may not occur for 7 days or more. Extremely cool or cloudy weather following treatment may slow activity of this product and delay development of visual symptoms. Visible effects are a gradual wilting and yellowing of the plant which advances to complete browning of above ground growth and deterioration of underground plant parts.
Stage of Weeds:
Annual weeds are easiest to control when they are small. Best control of most perennial weeds is obtained when treatment is made at late growth stages approaching maturity. Refer to the annual, perennial, woody brush and trees rate tables for recommendations for specific weeds.
Always use the higher rate of this product per acre within the recommended range when weed growth is heavy or dense or weeds are growing in an undisturbed (noncultivated) area.
Do not treat weeds under poor growing conditions such as drought stress, disease or insect damage, as reduced weed control may result. Reduced results may also occur when treating weeds heavily covered with dust.
Morning!
Just above freezing. Mild temps for the next week.
1000 homes and cottages are still in evacuation zone. Fire crews are still working the hot spots. Hopefully not much longer and people can return home. Hydro hasnt been restored yet, 100’s of poles and miles of wire to be replaced,with the frost just coming out of the roads they are taking a beating. Impassable for small cars.
Just back reading here and checking Email. Fix Breakfast and head out to Church. Got a brake job this afternoon to do....
Good morning everyone. Backreading is done. Got the Demon all apart and scraped clean. I thought i had a timing gasket set but didn't, so got that ordered amd did other chores. I have the parts now so hopefully get it back together. No smoking gun of leak zone which sucks. Fingers crossed.
