MRA scan is done. Man that was uncomfortable. In a tube like normal MRI, but also an IV with dye and my arm above my head the whole time.
ouch! I hope all will be well.MRA scan is done. Man that was uncomfortable. In a tube like normal MRI, but also an IV with dye and my arm above my head the whole time.
Hang in there Eric. Hopefully they find the issue...MRA scan is done. Man that was uncomfortable. In a tube like normal MRI, but also an IV with dye and my arm above my head the whole time.
They should be able to read it while it's happening.how long til someone gets results from itg?
hello eric, maybe looking at another Demon will brighten things up for you today!Hang in there Eric. Hopefully they find the issue...
The good part of it is I bet he takes good care of it.Well the car lives on just not in my driveway. Sad day but happy for Jeff and that it's going to a good home.
Not sure how long for results, but I can log into my chart and see. Follow up appt is Monday June 2. Right after MITP.ouch! I hope all will be well.
that is awesome.. btw.. a little tip. when putting the valve body back in, put the shifter piece into the case hole first then work the vb in.... I didn't pay attention one time and had it jammed in there and had to take the vb back off..
You are getting pretty good at those transgressions! LOL
Yessir...that is awesome.. btw.. a little tip. when putting the valve body back in, put the shifter piece into the case hole first then work the vb in.... I didn't pay attention one time and had it jammed in there and had to take the vb back off..
also.. i only put the pan on with 2 bolts and no gasket. then when it's in the car i adjust the shifter cable then put the gasket/pan on.. so there is no guessing you can make sure the detent is exact... or i usually center on the neutral safety switch and change gears a few times to make sure it lines up perfect..
Watching the game now. We were cruising when it was on.Indiana up by one after being down by 9 at the half![]()
Yessir...
I do those exact same things.
Easiest way to get the shifter cable installed and adjusted.
3rd 1/4 ended. The Fever is up. Don't tell me the outcome. LOL Exciting game.ah k, wasn't sure if you had done it before is all
Appreciate the Look Out...ah k, wasn't sure if you had done it before is all
My end-play paranoia is engagedthat is awesome.. btw.. a little tip. when putting the valve body back in, put the shifter piece into the case hole first then work the vb in.... I didn't pay attention one time and had it jammed in there and had to take the vb back off..
The game was exciting but not the outcome I had hoped for.3rd 1/4 ended. The Fever is up. Don't tell me the outcome. LOL Exciting game.
really enjoyed watching it though.. and i don/t like bball normallyThe game was exciting but not the outcome I had hoped for.
Hello Mike,The good part of it is I bet he takes good care of it.
