Stop in for a cup of coffee
Good morning, I seen that a driver at Utah salt flats died in a wreck trying to set his new record., hope your friend and member here is ok, firt thing I thought when I seen this news.
and we are live...
Prayers for all the people involved, see bad news this morning of a crash and the driver didn't make it @71GSSDemon
Took Victoria out for a test drive yesterday, checked for leaks with 8 gallons in the new tank, no leaks, ran like it should but, no fuel gage yet, need to look at my fuse box, I don't have a a horn relay in yet because I pulled it to test my sons old truck build 3 years ago.. good ground from chassis to new sender, we will see what I find today
Ground strap in last picture, fuel return line in the first.
I need to change the IVR on the POP, Big PIA to pull the cluster on it. At least yours is easy. Spedo cable sucks to get hooked back up on mine.
Thank you once again my friend, I just looked and my oil pressure lamp gage wire was never used or plugged in for this build, new I would be going mechanical.
Easy check then you know where the oil sending unit wire is in the engine compartment? Ground it it should peg the gauge then the same with the sending unit wire for the tank. If either move not the IVR.
If you model had only the basic oil warning lamp that will be a 12 volt wire and not related to gauges or voltage limiter
