Funny, I saw that ad earlier and immediately went in a search for a 64 Polara T shirt.
U saw that earlier and immediately looked for 64 Dodge shirts.
Talk to @IcetechI was never into early B bodies but I have a friend trying to sell me a 63 fury. Cool car but I'm not sure how easy parts are to find and it's kinda foreign to me because I've always been mainly A body 67 to 73
May have to ask @halifaxhopsSo is been like 6 or 7 years since my last electronic ignition conversation.
If I remember right a 1 ohm single row ballast resistor should do the job.... right?
I'm using all stock factory parts
Depends on the setup. My 64 is rolling a dual pin resistor with the new wiring harness.So is been like 6 or 7 years since my last electronic ignition conversation.
I have the stock slant electronic dizzy and the new harness.Depends on the setup. My 64 is rolling a dual pin resistor with the new wiring harness.
Adding the distributor pigtail was simple. There's kits
VR was unchanged as well as the coil. I did go to a high vibration coil because it's horizontal.I have the stock slant electronic dizzy and the new harness.
The voltage regulator looks like an old mechanical one but that's only looks, it's the later style internally and stock coil
Ok, so educate me on the coil.VR was unchanged as well as the coil. I did go to a high vibration coil because it's horizontal.
Pretty sure it's the distributor pickup and pigtail going to the ECU that changes
Yes..Ok, so educate me on the coil.
It makes a difference how its mounted, like vertical or horizontal.
I think most slant sixes are vertical
That is interesting because I took that coil off a fury parts car i have and most big blocks are mounted horizontal from the factoryYes..
Standard coil is oil filled. There's some risk when mounted horizontal that the contacts inside would be out of the oil and cooling. The high vibration coils remove that risk.
My slant coil was on the fender.
that intake/carb is worth more than what he's asking for the lot... damn man...
I had a Niva given to me, should have tried to get it running. Nope, i filled it with scrap. Some days i regret it.I still think a valiant looks like a lada, dang I love it. Always wanted a lada but I gave up finding one in middle America, plus it would be hard to daily drive it. A valiant really is America's car
Early B's are something I have never owned and something I wanted before I get too old. I am really enjoying my Polara.I was never into early B bodies but I have a friend trying to sell me a 63 fury. Cool car but I'm not sure how easy parts are to find and it's kinda foreign to me because I've always been mainly A body 67 to 73
