Stop in for a cup of coffee
Got the battery shut off switch yesterday and it is almost in cannot even see it in the tailpanel unless you are looking for it! Still have to get the metal toward the tailpanel about 3/8" more.
Fixin breakfast now for my Young Protege Helper and myself. Doing carpentry work outside today, and want to get done before it gets Hot...
I have been nailing the backing plate with a #10 and even tried a chisle to push the end of the axel out of the spider gears against the cross shaft nothing. Just wanted the 2.93 gears! Oh well.
My passenger side slid right out, but the drivers side was a pain, I used a big wheel puller/bearing puller to remove it, it was stuck good I tell yea..
How do you get the spiders out with a axel in it silly boy!
Just like the 8 1/4, remove the big pin and rotate till the gears fall out, I do have my complete 7 1/4 I took out of Victoria with only 60.000 miles on it, new drivers side bearings just 2.000 miles.. 3.23 gears
Drivers side also, took the pin out it would not let the gears fall out since the one is stuck to the axel or I should say the axel is in it. No biggie spent to much time on it for a $50 set of gears!
Hoping got the batt switch in yesterday all the engine wire is done except the nss wires will do those on the lift. Just moving the fuel hoses around today and get the batt wire to the front temp until lift time then it and the vac pump hose will go in some sort of pipe to the front.
fu(king awesome!! here's to it going without a hitch!!
I apologize for my tardiness in replying. I'm new to this online socializing. Ok I'm new to socializing period. I am greatfull for the folks here though. I,ve certainly picked up a lot of info and am becoming very fond of this site and its people.
don't get TOO fond - - you've read this thread - we'll burn (flame) you alive!!! LOL
