Stop in for a cup of coffee
Did you guys watch this? IT WORKS! I used a Dewalt heat gun and a spray bottle of water set on mist because I don't own a steamer. You can just watch the foam rise and the creases disappear. I think this would work GREAT when you are replacing seat covers. You may be able to use your old foam!
Before:
After:
I actually used to do that trick back when I owned the Auto Upholstery business. We would also put the new covers on and then run the steam wand up inside the covers to expand the foam and get a nice tight fit before finishing with the hog rings.
rack issues - what??? TMI :poke:
There are never any issues with a good rack... :D
I'll check out any rack to make sure its good!
No. Are you running anything else aftermarket IE adjustable strut bars or uppers or even off set bushings
No, no, and no. Now my front suspension is a mix match. Im running 72 down K member, with 73 up steering. It was recommended on here on numerous threads to reverse them, to allow the clearance so the calipers dont hit the sway bar when at full turn.
