zkx14
Duster De-ruster
It was just on the grass at work. Little bit starting to lay in center of road and shoulder. Got halfway home and it was a whole different story.That's all I got not even a covering.
Unpavedunpacked?
But where in the line?Oh wait yous bees a colledge edeucated, just stick it in line, don't over engineer it, just Beereneer it to see if it runs.
You are going to try and pump clean oil thru It first.?Gonna try putting that points set up in it tonight. And then hotwiring the electrical harness.
Car last ran in 2005 when it caught fire after being converted to electronic ignition. Reverse band is also supposedly out. Sad to report that it does have the trunion driveshaft so that further limits the selection of big block push buttons
Direct to. The gas tank.Yeah just have to figure out how to wired that in
As long as they don't have deep ruts, that can actually be better for traction.Unpaved
Fixed it!Oh wait yous bees a colledge edeucated, just stick it in the hot wire BEFORE the coil, don't over engineer it, just Beereneer it to see if it runs.
WOLFIE your bad!Direct to. The sending unit wire, just tape the main coil wire to it!.
That's what he said.I want to see what it looks like underneath.
might have a locker in it!I do have the figure out what locked the right rear . Had all four wheels turning but when to load it on trailer and it locked up tight. Guessing brake
If I was Chris I would hook up a remote starter.WOLFIE your bad!
Get my *** parked on a porta potty a save distance away.
It could be an oh **** moment. Best to be prepaired.
We talkin about your victim van?might have a hooker in it!
The tikey truck was pretty funny, like a potato gun out the exhaust but with acorns, that's what half a can of starting fluid will do!If I was Chris I would hook up a remote starter.
Yep, smells real nice. You get CD's?Bet you want 50 gallons of freebreze!
I hope he put it in neutral before dragging.might have a locker in it!
