Stop in for a cup of coffee
The a/c evaporator collects water and it makes it way out of a drain.
On humid days, it will ice up and melt off thereby leaving a puddle.
I like it when she melts off and leaves a puddle!
Yep and the older systems seem to have the problem even when you're not running the AC. Spring and fall are the two worst for ours. Ours gets so bad that it actually spits water at you out of the vents
If the defrost is on,even with heat running, a/c compressor cycles to de-humidify the air being blown on windscreen.
All good, just got finished putting in those lift struts in my '69
That's good. I think I have a spare set of those white nylon sliders, but I gather you already ordered them. I bought them thinking '67 used them, and then realized not so after I got them.
I assume your not getting much smoke?
