Stop in for a cup of coffee
Sometimes I've lucked out with plastic glues. I found some really good 2-part a few years ago that worked on the plastic nut that holds the spare tire carrier underneath. Stuff had awful fumes. Used it outside. Being paranoid, I drilled and wired reinforcing around it. I couldn't find it this time and of course I didn't keep a record of what it was.
It seems like it wouldn't be hard to cast out of resin. Just make a plaster mold of the wooden part and then cast using resin. You could probably use JB Weld to cast it.
JB has a bunch of formulas that are supposed to do plastic, but this one works! First used this stuff to glue a polypropylene filter housing for work that nothing else would work on. Have used on a number of things since with great results.
https://www.amazon.com/dp/B009EU5ZNO/?tag=fabo03-20
I thought about that! This fellow already has a prototype printed and the advantage will be he can make little adjustments to better match the original.
Deer are moving here at dark, morning and evening, this cold weather may help move them in day light shooting time, we will see. Good morning early crew.
10 degrees counting wind chill this morning :wtf::wtf::BangHead::BangHead::BangHead::BangHead: come on !! March on in here March !!
I work in the Agriculture chemical/seed/fertilizer business. Job doesn't need me (or anybody else) this time if year! We won't do squat for a few months!
Look up Gray seed farm in Arkansas, he calls on me to drive truck at times to and from fields, my family has been working for him for 30 years.. I know what you mean about nothing to do :lol:
Ran across this picture and giggled.
