zkx14
Duster De-ruster
Doesn't take much to air up tires. I need to get a new one myself. Found a pin hole in bottom of my tank recently -11gal 2HP that I got used years ago off CL. Might check how the pressure switch is set up. If I can knock it down to 50-60 in the tank, I would not be afraid to continue using it temporarily. But It's going to leak down every time I turn it off, so never going to have air right away. I have one that is just for tires, but so slow...I'm going to go buy a better air compressor. I want one to air up the truck and trailer tires nothing else. I'd like one small enough to put in the trailer when I take extended road trips.
Thinking the eight gallon size, quick recovery, 150psi??
Don't want junk any recommendations??
