You can mod the /6 wiring harness if it is in good shape.
i looked into an over haul kit, figured $230 upfront is a lot better than 3k down the line.I have a 8 1/4 and it seems to handle it well so far. REBUILD the tranny! Just blew mine and it was a used one I got with the motor.
If I had to have one... I dont think more than $100 each for engine and trans. If your lucky enough to find a buyer. There's too many around. Unless its recent rebuild, or some 'special' parts, maybe a bit more. But even then there's the 'who worked on it question'. I would be surprised If anyone took it as trade...
A pristine exhaust manifold is worth more than the rest of the block.
your not living ....should be thong day everyday. you don't want those panty lines showing through ....right. ****LMBO thinking of you in a thong****
Just ordered one from Jeggs, mine has a hole in the case so by the time I would get a core and the parts it is just a few hundred more so what the hell!
My harness was in great shape so I just checked it out and did the mods as needed and changed some terminals out.
Speaking of which the truck should be on the road next week, got room for the motor?
But you did the same to airplanes!
Man I was a wiring fool on the 130's! Rewired at least 8 full fuel tank indicating wiring systems. Prob about 3/8 mile of wire on each one!
I'll probably list it at $500 obo for trans, engine, filter to pan.
I can hold on to it is in the old chicken coup not bothering anything.
I always liked the 130's. One badass aircraft..
Workhorse! The stories I could tell you! Always liked the pave hawks better but that's a helo!
Since you said ypu are going to have it running...keep it in to sell. Much better chance of getting higher $ if buyer can at least hear it run. Better yet if they can drive it. Then your tranny value goes up a bit. Still most will consider it a core unless you can show low miles or receipts.
