Stop in for a cup of coffee
Hey still on for the 16th I have to drop her off around 2 or so with the tsa wait now I think, Her flight is 5 or so I believe.
1 # Pre-wash, clean 1 1.0
Note: Press wash hood, fender, engine bay..Soot removal
2 ** Repl A/M Wiring harness, engine 10127 1 574.99 8.0
Note: Painless Performance Products LLC
2501 Ludelle Street - Fort Worth, Texas 76105 Phone (817) 244-6212
3 # R&I Carbuerator 0.7
4 # Repl Carbuerator, overhaul kit EDL-1477 1 49.95 2.0
Note: Summit Racing Equipment - 1-800-230-3030
5 # Repl Intake gasket kit MRG-5994MRG 1 139.95 1.5
Note: Summit Racing Equipment - 1-800-230-3030 - Incl. intake manifold and valve cover gskts
6 # Repl Plug wire kit w/dist cap SUM-867807CR 1 56.94 1.0
7 # Repl Air cleaner assy EDL-1002 1 20.99
8 # Repl Brake booster, m/c assy RSD-G80011001 1 235.31 1.8
9 # Repl Radiator hose kit 1 21.99 0.6
10 # Repl Battery B30% 27-3 1 116.99 0.2
Note: Advanced Auto Parts
11 # Anti-Freeze (Per Gallon) 2 24.00
12 # Material & Supplies 1 20.00
Yep. Kinda generic..
I am also going way beyond it with the moving of the battery to the trunk along with the vac pump and canister. I want to run the wire and vac line in electrical conduit from the trunk to the eng comp. Glad I have a lift now and a conduit bender left by the previous house owner. Still throwing around a fire loop in the engine comp. This might be a while to finish and miss this summer to run around! Dam the engine was just broken in also!
Still do not know what else is messed up until it runs, sensors, elect boxes etc.
Keith still need those lower fender clips and studs? I have a good pair from the belve, I am starting to box what is left and they are in there.
Actually that is fairly detailed. Lookes like each price is followed by labor hours. i.e. 574.99 for a painless harness and 8 hours to install. they only gave you a rebuild kit for the carb though. 2 hours to rebuild it and .7hrs to remove and install....
.7 is a joke takes me a few hours with cleaning it. I usually take all the lead plugs out and blow out the passages then put them in and jb weld over them to take care of any leaks.
I have a froggy or should I say toad that hangs with me in the shop. Named him Fred. Weird kind of hangs out by me when I am in there. Don't think he will last long when Harley visits!
they would put that in the rebuild hours, only if it had to be done.. will only give you shop time for the min a shop would do to get it going. Now if you show that it is not rebuildable and had to be replaced... that's good for the amended claim. Be sure if you need little stuff, sensors etc that they give you the labor time. Probably more $ than the part!
