Stop in for a cup of coffee
Well I made it home, no drama, which is good. Still weird idle problem. Timing is rock steady... NO vacuum port at all to put a gauge on. NONE! Have to put a fitting in the manifold.
Do you have another carb you can swap on? if not, I would pull that one and tear it down and see what it looks like inside. It may be full of varnish or have debris in the bowls.
I can't believe I'm the only one who caught this. Or maybe I should just grow up! Nah!
Minor rear vibration.......
Besides the temptation to make the obvious wise-*** response, I can't believe the OP states he has two rear tires that can't be balanced properly and one that is out of round...and is looking for other reasons why he has a vibration. Ummm, could it be because one of your tires has separated and is in the process of destroying itself?
Naaah...
Naaah...
That's the other reason I chose not to comment lol
Naaah...
Yeah, that's what I thought after reading the post also. But decided rather than hurt his feelings (because I'm not sure I can state the obvious without bringing CFS into the statement)I would go for the potty humor.
Dam you better pay for the room, mom just don't look so good any more, but on the bright side grandma lost her teeth!
Haha
Look out! Hoppy's on a roll! Take cover!
