Stop in for a cup of coffee
Yep
I'll check out any rack to make sure its good!
No, no, and no. Now my front suspension is a mix match. Im running 72 down K member, with 73 up steering. It was recommended on here on numerous threads to reverse them, to allow the clearance so the calipers dont hit the sway bar when at full turn.
Have you driven it? That doesn't sound right at all
73 + spindles are rear steer as well so I really don't understand how you're running them as front steer with that linkage
Just flipped the spindles side to side ? Everything else as it should be rear steer? bit confused myself
Yep about 3k miles on it. 72 down is rear steer as well. Just swap the spindles from a 73 car to get discs. If you want to run factory sway bar reverse the spindles and ball joints. Its been pretty common on here.
have they told you how long it'll take to heal?
No...
I'm a fast healer, but I don't want to heal too much yet before it's set back in place...
Then I will try to help it heal faster with tons-o-milk to supply calcium & let my metabolism be the bottle neck, like when I broke my leg 30 years ago...
it never friggin' fails though huh - can't do it right at the end of fall - - oh no, it has to happen mid to late frikkin' spring...
Yep... Already itching.... And it's not that hot yet...:BangHead:
They must think that i'm made of coat hangers... (abortion joke reference)....
No...
Ummmm...I'm thinking it will take a bit longer now than 30 years ago. Metabolism and osteoclast/osteoblast function for bone rebuilding changes dramatically with age.
When you are young, your entire bone structure is rebuilt every 90 days or so. At age 50, it takes closer to 18 months which is why osteoporosis is such a huge issue in men and women in their older years. When the hormones estrogen and testosterone begin to wane, the bone rebuilding process slows massively.
that's why i drink milk regularly...
