Stop in for a cup of coffee
Guess I'll play with my putter since nobody wants to chat.
I once worked with a guy who asked "If a gas cylinder has 2500 lbs of helium in it, how can we lift it?"
We explained that it's not weight, it's pressure. We the explained how a small amount of helium in a cylinder is actually a large number of cubic feet of gas when it's released.
He thought about it for a minute and then asked "Well, if there's that much helium in the tank, why doesn't it float away?"
Seriously.
Of course, this was the same guy who asked if chicken breasts had nipples.
For some reason, my day at work reminded me of that guy.
Seriously.
De-nippled chicken breasts? That's what I cook:lol: on the grill!
Seriously.
I've had to deal with folks like that.
Wolfe, did you ever notice the faster you drive the harder it rains?
So, laptop died. Cant make it worse, right?
Pulled keyboard and split the bottom open as far as i dare go.
The new brake cleaner is alcohol base,so i pounded a bunch into laptop below keyboardand in from underside. Then set it on its side and wedged adjustable blow gun into housing and gave it a breeze for 20 minutes. Plugged battery in and it turned on. Back up and running. I got lucky....
I used that trick to fix a CPU in a car that was under the passenger seat. The girl who owned the car dumped 3 big gulp sodas that she was carrying on the floor all over it and flooded it.
I pulled it out, opened it up and did the same as you. It worked fine after that for another 5 years.
Speaking of which, It's getting time to vacuum my keyboard. No wonder why my keys stick sometimes. LOl
Solving problems with alcohol.
Well if someone loaded me with alchiehole and blew on me for twenty minutes.
I would... Well I just WOOD.
