Stop in for a cup of coffee
Well, I need to go back to sleep... I'm catching another cold and trying to fight it off so I don't have to call off work...
LOL I had no idea you needed that I have to check the FSM and see what they say. I have only done 8 1/4's and rons front dana 30
How would you center that in say a 8 1/4 with the adjusters for the ring gear or it doesn't matter?
Where is the snow?
They shut down th city for this:rofl:
I guess all the snowflakes are in the house under their blankies.
I'm talking about pinion depth, relative to the centerline of the carrier case. You are asking about ring gear backlash. . On adjustable Mopars , It is easy with the adjusters. On theses GM cases, you shim the carrier from side to side to get the desired backlash. Use a dial test indicator for that. But this is all , AFTER you have the correct pinion depth, and the pinion is installed in the case, with the proper peload on the pinion bearings..
I only have one question....
Where are the pics? !!! :poke:
Sorry forgot my phone. I'll be back in a couple weeks and will get some. They have a Facebook page and have hundreds of pics for those snowed in. Shop has over 200 national awards for cars and trucks they've done. Bright Build Hot Rods.
I understand that, seriously always done it like in the instructions I posted. Just by the wear pattern on the ring gear and check the backlash also. Like I said I make the shims to the top of the pinion the same as the old one and check only once I had to remove a small shim. Hey @memike how did you do yours? Just curious.
Keefer you are a good blower!
It sucks out plowed not blew around 8" and walk to the house and it snowed another inch on what I plowed!
