Stop in for a cup of coffee
That's different. back glass on the 67 is glass first, trim 2nd. Same for 68-9 but I think clips may need to go in first.
I screwed up, neep help
66 - has double trim around the back glass. First piece gets screwed on under/with the trim clips. Then glass. Then pop the second trim on. And the trim on top of the quarters goes under the bottom of the first piece of window trim!
We got the proper spacers on the alternator bolts of the Roadrunner today...
May go work on the older kids Valiant soon... Put the Hoppy distributor in...
Sounds good. I was surprised at the number of different spacer lengths in the parts books.
I put some new bulbs in the garage, did a little cleanup, and am about to try to install a dash light in the wagon. Lots of fun since it has A/C..
almost done
Thats what She said........Beat Karl....
I was wondering who’d say it first
Heck with nuts and bolts, use the flex glue to put everything together... :rolleyes:
@dukeboy_318 should have used that stuff to install his Hemi yesterday.... :poke:
haha
Man, that sucks...
maybe you should have used more attachment points to distribute the load...
I used a lifting chain, same one we used when I worked for Cummins lifting N14s, two anchor points. Used it on every engine I’ve gotten with no trouble until now
Don't those late Hemi's have metric threads in the back of the block ??????? :eek::eek::rolleyes::rolleyes:
nope. They are the exact same as an LA, Magnum and poly block. Even the length of the bellhousing to block bolts are the very same. 3/8-16 UNC. Verified with a certified SAE engineering thread gauge kit. And reverified this morning. Looked it up on Alldata to confirm as well. Only difference it the bottom two holes for the starter are 7/16.
If you look at the picture, you’ll see the block around the threaded hole is crackers question is, did that happen before or during the pull out
Yep, those should have all metric threads...
Nope, see above.
Chris used to put the square peg in the round hole when he was little.... :poke: :D
haha
Anyway, after the Tylenol kicked in, I managed to finally pull the seat in the polara and cleanout the mood nasty carpet. 4 feed sacks worth of crap later, I finally found the floor
About 12 sq feet of flooring left to do today.
Then one short hallway and a small bedroom.
