Stop in for a cup of coffee
How I feel about the Guard right about now
Oh I felt that way many times. I sure enjoy the monthly check and free insurance now. Glad I stuck it out.
Need to go get a small can of paint mixed for the Barracuda today.
When buddy painted it he left the glovebox arms (attach to the glovebox door) down. The small area behind the mount is still primer...ugh... Didn't have any left over from the original job.
Going to pull off the old harness and clean up that area and touch up the harness brackets.
This week really sucks! Sitting here waiting for a tow truck and wife to pick me up. Some numbnuts just slid and wiped my whole drivers side of the magnum from wheel to wheel. Door stuck so had to get out passenger side. Still drivable, but got a chunk of his plastic stuck in the bead of my back tire. So, don't trust it.
Hope your getting some sleep now.
Make sure they get you a rental so you don't have to drive Cinammon.
I had a rental all summer when the Barracuda got hit, but every situation is different...
Got an airbrush? o r does he?
Whats up here today. Every time I click on something I get the must me logged in error message. I've logged out and in twice now.
Anyone else have that problem??
Chris got to figure out whether its you or the job, and just temproary or not. Every job is going to have its tough times, as general nonsense, thats different to being than being no longer to physcially or mentally do it.
If I remember right I had to cobble mine together from parts and move a tap on the cross bar.
Ok, I will look into what it will take. I did send a PM to Rainy as suggested. Otherwise, will head up to the junkyard when I have time and see what can be found. Even the junkyard isn't fun in single digit temp that will be coming
I remember I got a few in and none worked. Just took what was needed and made it. I wish some one made a cable kit for a column. I still don't really like the feel of it.
pretty sure the linkage on mine from the steering column down to the pivot is from the /6 904.
Ugh. Cant remember.
Think used a cross bar (z) from a slant and moved one of the tabs on it.
For the first years I used a piece of aluminum angle withc a hole drilled in it for the transmission side. Wasn't perfectly square but it worked.
