I eat Mitches steaks from Omaha!
Dang - Why are you so far away? Seeing the dirt and dust on the steering column and just the general condition this afternoon got me thinking I should find someone who knows what they are doing.Spent about six hours today detailing out the Barracuda. Another hour or so and I'll be done.
Detailing an old car, I find it therapeutic and enjoy it.
So the piece in tire,is from the tire machine. Not unusual.This was what was in the tire.
and another learning experience.
Or this the norm these days?
Yes the tire machine piece - that probably explains the rough edges on some of the rims. Guess the guy didn't notice it broke off.So the piece in tire,is from the tire machine. Not unusual.
You are referring to the stick on weight adhesive stuck all over?
??????????????????????????????????????????????????? NP ??????I used to hate adjusting the USAF wrenches. Avionics was the shop that did the bases. Everything from 1OZ jewelers screwdriver types for NVG's to 1000ftlb ones for the mounting of props. Sucked big time since every time they were dropped they had to be re calibrated. Totally threw them off. Plus the calibration cycle was every three months also. So a few hundred on base meant job security for all!
OOPS I did it again!Not much choice on some of this stuff Keith.
Who would check and adjust a steering box?
Yet all in all it was pretty easy.
Just a bit time consuming.
Too cheap to buy a torque wrench that does 1.5 - 11 in-lbs, I used a cheap spring scale that goes 0-18 oz. and did a little math.
Now here's a question I probably should post in suspension.
Why does the '67 Plymouth FSM show the torque to reattach the steering arm at 120 ft-lbs, and the '68 and '69 show it at 175 ft lbs?
AFIAK the manual steering box never changed. I went to about 130 this time.
me be Keith. Other Z-dude be Craig...Not much choice on some of this stuff Keith.
Fishing weights.And the new fancy adhesive wheel weights really messed up all of us that used to collect wheel weights, melt em down, toss the clips and cast bullets out of them. The new ones suk.
