Stop in for a cup of coffee
Need to put a little rubber grommet on the top of the hood pop up spring. Seems the top of the spring is scuffing the bottom of the hood where they meet when I put the hood down. Never had this problem before.
I can get something to leave on and then pop off when I'm showing the car. Seen others do it just never paid attention to what they did.
Looks like a trip to the hardware store.
A rubber crutch pad might help. Yep, hardware store should have what you need. Menards has a bunch of that kind of stuff as well.
Why not try a vacuum cap on the end of the spring...
Either the vinyl or rubber type.... (That's what she said.... :D )
Funny you mentioned rotor my antenna is on a rotor and it is not working right just picked up a omni directional antenna plan on putting it up this weekend.
This just the rubber
I thought about checking the plumbing section sure I'll find something.
I have seen people use the same rubber off of one of the hood alignment supports up on the cowl that can be adjusted. Forgot the name of them.
And I think I have a couple of those somewhere in the garage.
@toolmanmike
Mike did you ever get one of those battery topper plates. I saw you in the thread I read this morning.
My resto battery is fading again. I'm not buying another one, time for plan B.
