Black RTV.Do you guys think I need new strut rod bushings....
I think they might last another 50k miles....
24:1 or 20:1 at most unless you've been working out.Not yet but I am converting to manual.
No, I think you just need a sharp knife, and cut them in the cracks and make them look nice and then glue them together with crazyglue.Do you guys think I need new strut rod bushings....
Just replace em with a couple rolls of black tape...Do you guys think I need new strut rod bushings....
This car is going to have 0 power options
I usually just use whatever I find.... all my A body cars have manual steering and i have never had a problem.24:1 or 20:1 at most unless you've been working out.
Yes wrenching counts (at least partially I think)
I need to get rid of this bulky *** thing.
I like manual brakes because you know what you're stepping on. If manual brakes don't stop you, then step on it harder..... so simple.
I don't like these boosters because when they mess up, they cost a fortune to fix or replace. It can stop from the bottom of the junk pile.
I shot yall some videos today. Sorry about the sideways shot. They are pretty self explanatory.
Here's Matt workin on replacing quarters on David's Chevelle.
Mopar always said that a power boosted brake system just becomes a manual brake system if the booster ever fails. If the power booster ever gives out, just treat it like you have manual brakes with only a little extra pedal travel.I need to get rid of this bulky *** thing.
Looks nice. a little pricey, but it seems complete...What do you think about this brake and fuel line flaring kit? Was looking at buying it.
FAIRMOUNT® Hydraulic Flaring Tool
I liked being able to do the fuel injection lines as well. I had a real good flaring tool at work from LG for refrigeration systems but liked the fact that this kit makes it easy to flare on the car.Looks nice. a little pricey, but it seems complete...
A few things to consider, not knowing the bore of your single master, i will go with the 1.25” one in my fargo. When switching to dual you will want to go to a smaller bore. Dual masters displace 2x roughly what single lines do.Well, since I am over 50 i have an excuse when it.comes to my memory, ha ha. Anyway, if I remember right someone here on fabo had done a conversion from single circuit to dual circuit brakes and used the master cylinder from 1967 or 68. But, I think it said that a master cylinder from 1971 or 72 or so would have been a better choice, it would have required less push with the foot to stop the car.
Bill
I would have kept that, rarely troublesome and a small level of security. Keep the honest people out.I took the time to get rid of the inside hood release which never worked.
I don't like that this was a high option car, more that I have to get rid of because my whole intent of this build is SIMPLE.
I don't mind optioned up cars, in fact I like it when I find high option c bodies but this scamp is going to capture the old time feel of a rambler or a really simple car like that
This one has the knob busted off and the cable is brittle and chunks of plastic falling off.I would have kept that, rarely troublesome and a small level of security. Keep the honest people out.
