Just remembered, 6 bolts need to be fitted to crossmember. I relocated it, and only drilled 2 holes. Going to experiment with a drill chuck to extend the bit.
What to do when drill bit is too short...View attachment 1715464076
You were missing a Hot Dog?Hot dog! Found the missing part of the wiring harness I need for the Polara today!!
Dry Snow is better than dry hump, with a guy in the warm...Jus sayin.....LOLBrrrrr, it was like a warm spring day yesterday when I into project heavy Chevy.
Today, the temp is dropping quick and we're getting dry snow
I'll take your word for it.Dry Snow is better than dry hump, with a guy in the warm...Jus sayin.....LOL
Check the nut behind the interface of the condunrance, after that, it could possibly be the short spot in the Ion unit...not sure, but if i see the problem, i can know better...Ohh also check the Air, on the downside of the up shoot, near the crosshaft...So trying to figure out why my welder keeps randomly shutting off. It’s not the duty cycle. It’s like It keeps loosing power
All connections test good and are tight. It’s something internal
You think?Check the nut behind the interface of the condunrance, after that, it could possibly be the short spot in the Ion unit...not sure, but if i see the problem, i can know better...Ohh also check the Air, on the downside of the up shoot, near the crosshaft...
Low Voltage?All connections test good and are tight. It’s something internal
