Stop in for a cup of coffee
Dana 60s will take the "Sleeper" image away from pretty much any hot rod. :thumbsup:
they'd have to crawl under my car to see it. The way the rear suspension is plus the fuel cell and rear valance/diffuser combined with it being lowered, it'll be hard to see.
Right at freezing up her on the tundra this morning. My grill I purchased off FB made it in yesterday. The seller just put it in a box and marked it fragile, so it is now cracked in the center. I would have at least put a piece of plywood in the box. Holy smokes. But the grill still is a marked improvement over my current one. Technical question to all you plastic savvy folks. What is best glue to use on the crack and do I need to stop drill plastic? The crack is on bottom so I think repair should be graceful. I will post a pix tonight when I get back to shop.
As I remember I believe someone in the site used acetone and shavings from another grill and made a filler/glue type of concoction.
A lot of these parts are ABS. Real fine line can be welded with acetone. Chips will need some plastic mixed in or an ABS cement.
instrument cluster repair what glue to use
I found these two webpages helpful:
Intro To Solvent Welding Plastic - Homemades - NerfHaven
Identify Plastics
the link to this thread is further up
How do you glue these back on?
also good
Identify Plastics
also good
But so cool to see peeking out just a little.
:lol:
besides, I have a GIANT hemi scoop on the hood, there aint no hiding this thing. and a 440 with purple hornies oughta be loud enough to shake fillings.
High school buddy's 70 yr old father had a Hemi Roadrunner similar to this
but with steelies and wheel covers. The Hemi emblems on the little faux hood scoops were tiny. Soon as you got around the back and saw that Dana, you knew it was not a 318 in there :lol:. Bench seat, column shift 727, dual quads, factory sleeper all the way :lol:
His daily driver.
High school buddy's 70 yr old father had a Hemi Roadrunner similar to this View attachment 1715523521 but with steelies and wheel covers. The Hemi emblems on the little faux hood scoops were tiny. Soon as you got around the back and saw that Dana, you knew it was not a 318 in there :lol:. Bench seat, column shift 727, dual quads, factory sleeper all the way :lol:
His daily driver.
if you knew to look for it lol
Wasn't trying to be Political in any way. Sharing for friends...
Friends don’t let friends do politics, lol.
So much ‘information’ circulating right now. You can find stories and statistics to support anything you want to believe. I’m just plugging along through it. Wear my mask and try not to get arrested for going the wrong way in the grocery store aisles.
It's kinda fun driving against the arrows for a change :rofl:
There is a tremendous amount of fake news, reports, stats, etc for any and all sides.
It seems I have lost a good friend to Covid-19.
Did a Home Depot stop just a bit ago. Walked right in. Got a couple things and quickly thru the ‘short term employee’ checkout. Although a real employee had to assist me and verify I was not a teenage spray paint huffer. Lol
