I might need help getting the VN top on it correctly. I'll contact you....We always called those “clip tits”. For screws on the ends I always put dab of clear silicone in the hole before running the screw in. Never had a leaker.
Cool, glad to help. I got PosiRon hooked up with his. Turned out well.I might need help getting the VN top on it correctly. I'll contact you....
Will probably need your expertise on the headliner as well...Cool, glad to help. I got PosiRon hooked up with his. Turned out well.
No sweat! Just remember you have to put the headliner in before the front and rear glass and best to do the top after the glass is in. Just so you can plan.Will probably need your expertise on the headliner as well...![]()
We took Thurs and Fri off. Got more hail Sat and Sun. Just smaller stuff tho. Still makes a mess of tbe yard. Tired of cleaning up.Jeez, what’s going on in Texas and hail? Rick said he got hammered with tennis ball sized hail and they had grapefruit sized hail in North Texas Friday.
Good place to start is the Factory Service Manual. Should have complete basic motor rebuild info. At least give you an idea what your getting into. If you need the FSM, they are available under reference at Mymopar.comThinking about rebuilding my motor if the compression test is bad. Any tips or tricks if I do? It would be my first rebuild. 66 dart 273. View attachment 1715534568
I have a recent rebuild in my 66, 318, runs great, that I might sell if you need it. Complete.....See it run and drive....Let me know...Thinking about rebuilding my motor if the compression test is bad. Any tips or tricks if I do? It would be my first rebuild. 66 dart 273. View attachment 1715534568
What year of teen?I have a recent rebuild in my 66, 318, runs great, that I might sell if you need it. Complete.....See it run and drive....Let me know...
O and I like your car...
67. With swirl port heads.....4bbl in my Dart...What year of teen?
Nicccccccccce67. With swirl port heads.....4bbl in my Dart...
So a 67 date for a 67 model year or 67 date for 68 model year?67. With swirl port heads.....4bbl in my Dart...
I am sooo tempted to keep it in the car, I have been all over the idea of putting a 408 stroker in it, I actually bought a 408 from @Johnny Mac and have collecting the neded parts to in stall. BUT the 318 runs so good I might keep it and sell the 408!!!Nicccccccccce
It came out of a 67 Camper van. A100.So a 67 date for a 67 model year or 67 date for 68 model year?
I like the way uncle Tony put it,..... you really have to define a purpose for the car to determine what is the right amount of power you should be getting out of it.I am sooo tempted to keep it in the car, I have been all over the idea of putting a 408 stroker in it, I actually bought a 408 from @Johnny Mac and have collecting the neded parts to in stall. BUT the 318 runs so good I might keep it and sell the 408!!!
That's a cool vehicle going more to the extinct sideIt came out of a 67 Camper van. A100.
It was real low mileage, but had the top cut off for the camper setup.....ruined...That's a cool vehicle going more to the extinct side
Thanks brother. But I'm keeping numbers matching. The compression is good. I noticed that my coil is getting too hot. I tested spark but its intermittent. Brand new coil. I think I'm in for an electrical problem. I'll tackle it tomorrow.I have a recent rebuild in my 66, 318, runs great, that I might sell if you need it. Complete.....See it run and drive....Let me know...
Almost had to hit the disagree button!! Lol.I am sooo tempted to keep it in the car, I have been all over the idea of putting a 408 stroker in it, I actually bought a 408 from @Johnny Mac and have collecting the neded parts to in stall. BUT the 318 runs so good I might keep it and sell the 408!!!
Distributor needs work.Thanks brother. But I'm keeping numbers matching. The compression is good. I noticed that my coil is getting too hot. I tested spark but its intermittent. Brand new coil. I think I'm in for an electrical problem. I'll tackle it tomorrow.
Sparky work on it?Thanks brother. But I'm keeping numbers matching. The compression is good. I noticed that my coil is getting too hot. I tested spark but its intermittent. Brand new coil. I think I'm in for an electrical problem. I'll tackle it tomorrow.
