Stop in for a cup of coffee
I've been looking for a front plate bracket on there. No luck though. If I don't find one soon, I'll probably just make one.
Not much to them. This is 75 duster.
Not much to them. This is 75 duster. View attachment 1715562970
Does that go under with a center bolt? Looks like someone beat the snot out of it and mounted it wrong. lol. I think the top 2 hols mount in the bumper and the lower bolts of the plate go to the middle holes of the bracket. What doesn't make sense on the one I pictured in my want ad is it has the nuts on it. My bumper has the square holes in all three spots to put the threaded plastic pieces in and have the screws go the other way. And as said, the parts book pics I found don't show it. Can you get a measurement vertical center to c-to-c between to the holes? That would be how far it drops the plate.
The plot thickens. Plate goes under bumper and uses one bolt in the center lower part. Looks like plate screws to only top 2 holes. This thing is almost flat on the ground. One broken torsion bar and flat tires.
Pretty damn hot here for two days now. 95 deg. Just finished cutting grass, but still have to blow the debris from the driveway and walkways. Had two of my Salvadoran guys here to soffit and metal wrap the rake boards on my old ( 35 yr) shed. The carpenter bees were tearing up the boards. Now they are just out there Buzzing around..Lol
View attachment 1715562990 View attachment 1715562991 View attachment 1715562992
What kind of trees are those??
There is a row of Leland Cyprus trees along the property line behind the shed. Planted those for privacy 30 years ago. Now they are 60 ft tall. Behind them is the neighbors yard. Those trees are , Pin Oak, White Oak and Poplar trees. I have mostly White and Red Oak trees, and Poplar, and a few Pines, and a few Holly's on my 3 acres....
That one i took a picture of, its higher on the bumper, plate doesent hang as low. And the top holes hold the plate. All these little differences get confusing as to whats correct.
I think they could have made them all the same. Engineers were like “You know, we could really fk with some peoples heads 45 years from now.”:rofl:
