Cold here tis am, see frost on the grass is heavy.
High of 78 here today.. Wind will be blowing like fat chick after prom tho.Guess winter is finally starting!
A little more mild here, south of you. 62 deg today and sunshine.Cold here tis am, see frost on the grass is heavy.
If they are bare now (not painted) I would use slip plate on them.I'm pondering whether to paint my new KH calipers before I install them or not? And if so, what colour?
Not familiar with that stuff. Is it a primer pre-coat or a type of finish?If they are bare now (not painted) I would use slip plate on them.
West Texas is good country for wind!! I used to live in Roswell, just over the border...High of 78 here today.. Wind will be blowing like fat chick after prom tho.
Pictures or it didnt happen.Good morning! Breezy this morning, projected 40+ mph gusts midday.
Big day, ...just got a FedEx notice my 3/8" header flanges are arriving today. Got a bunch of 1-7/8" tubing sitting here also. Planning a header build. May take me forever!!
If i recall, its a graphite spray.Not familiar with that stuff. Is it a primer pre-coat or a type of finish?
Its a graphite dry lube keeps cast parts looking brand new. Posi Ron turned me on to it does a incredible job an high heat it is fine with also. Google it for pics.Not familiar with that stuff. Is it a primer pre-coat or a type of finish?
But you can also buy it in a tub to rub on, if your manifolds are on the car , and you dont want to make a mess, right ?
