Stop in for a cup of coffee
JUst checking in. Got back home from across the state and the funeral. I have a Glen Carin and some Rittenhouse Rye. Reeeelax!
So this is how my day started. After picking it up, i cut the pan and flipped it end for end.
All welded back together and pulled pickup tube to lengthen it.
And thus is near the end of the day,installed and went to test fit pan. It touches the oil pump. Never saw that coming.
So tomorrow i put a relief in pan to clear oil pump.
May have to cut tube and angle it inwards a bit. Will see after i make room for oil pump.
We a bunch of running around today, JD first, then the auto body supply to see if they have all new clips and fasteners for the front facia? on the R/t then that will just need tires to go on the road. Hope the tractor is not going to break the bank!
No brick day.
Yesterday I got rid of 60 5gal buckets of millings.
I could have used them for back fill..
He needs it more. Going to grab the dump truck and pickup some clean fill and re level the rest. Then back on it.
Cars are really green this morning.
