Driving truck to grass valley today. Then in the AM towing a trailer from there to Boise Idaho. Long trip. Then Tuesday driving home. 930 miles home.....one sitting. Only stop for fuel...
Even if its works OK, would it be 'better' or easier to use than his 220 V welder?Flux core works ok......for most stuff.....now, the harbor freight welder not so much....
Again......Oh Boy! Donner Pass with a trailer!![]()
Again......
Good thing they have runaway ramps!Oh Boy! Donner Pass with a trailer!![]()
T/A?? The car or her (T/A tits and a**)PS That TA is currently in inventory at Smoky Mtn![]()
The 220 is a Lincoln 180 PRO, even on the lowest set, with the gas pressure turned down to about 8 psi, it blows thru even on tack welds. Even with .024 wire, the thinnest the machine can handle. It’s useable but figured for 100 bucks, I’ll try this one and see if that helps. If not, oh well. I’ll put it in the tool trailer I’m building for field repairs.Even if its works OK, would it be 'better' or easier to use than his 220 V welder?
Granted we know nothing about that one other than its 220 V.
Something only Chris can answer.
Just wanted to straighten out the misperception that what it plugs into relates to capability on sheet metal.
What you have should work fine...the 180....The 220 is a Lincoln 180 PRO, even on the lowest set, with the gas pressure turned down to about 8 psi, it blows thru even on tack welds. Even with .024 wire, the thinnest the machine can handle. It’s useable but figured for 100 bucks, I’ll try this one and see if that helps. If not, oh well. I’ll put it in the tool trailer I’m building for field repairs.
I have the same. Older version....goes down to 30 amps.....What you have should work fine...the 180....
It’s doing OK.I have the same. Older version....goes down to 30 amps.....
Sheet metalIt’s doing OK.
I did on the dart. Worked ok. This is more to compare.Sheet metal
Burp weld it!
Gas, turned up. To prevent porosity in the welds.The 220 is a Lincoln 180 PRO, even on the lowest set, with the gas pressure turned down to about 8 psi, it blows thru even on tack welds. Even with .024 wire, the thinnest the machine can handle. It’s useable but figured for 100 bucks, I’ll try this one and see if that helps. If not, oh well. I’ll put it in the tool trailer I’m building for field repairs.
Hmm how does using the steel tig rod work?Gas, turned up. To prevent porosity in the welds.
Ampereage on lowest level and wire speed turned up. Rusty body metal? Forget it. Tack tack tack. Fill holes. Use a steel tig rod as extra filler or a coat hanger . My lincoln 180 was fine for body metal. Im using an esab215 mp now. I prefer to weld with .030 too.
You feed it into the weld puddle.Hmm how does using the steel tig rod work?
