Hearing the bendix rapidly clicking like that, leads me to think not enough power to engage it to start.
OK. Then maybe the next most logical step is to do the same at the relay.
See if the starter turns over when connecting the solenoid to the battery terminals.
Yes a screwdriver works -
Battery tests fineOK. I'm going to guess that there is enough power (Watts) to the starter when the solenoid is directly connected to the battery. And not enough juice getting through when going the relay.
So the question is why?
Some possibilities:
Weak battery?
Restriction in the circuit to the solenoid?
Starter failing and demanding more power?
CheckingOK. Then maybe the next most logical step is to do the same at the relay.
Open circuit with NSS
with the key
Battery tests fine
new starter, new starter relay.
I don't think we know that for sure. Are you referring to the 12.7 V after charging? That's an indicator, but doesn't really test how strong it is. A better test is with a hydrometer, and the best test is under load.Battery tests fine
So then the problem is the wiring?new starter, new starter relay.
No no no what I said above was two separate points. I took the NSS out and tested it as you said, same message as before.Thats not an open circuit!
If that's what's happening with the NSS hooked up, then the NSS is working fine, and the relay is working.
Do you mean starting the NSS terminal grounded, then you could say bypassing the NSS.
Is there a way to check the voltage at the relay with this multimeter?I don't think we know that for sure. Are you referring to the 12.7 V after charging? That's an indicator, but doesn't really test how strong it is. A better test is with a hydrometer, and the best test is under load.
A crude way to check power under load is charge the battery, then watch the battery voltage while it turns the starter. If its above 9.5 V it should be good enough to do the job.
Lets hope new is good but we know thats not always so.![]()
That looks awsome! You did great!78F and extremely humid… Just gathered a few things from the garden. Best crop of beans ever for me. Did climbers again. Same set up as last year with 2 posts and strings hanging between. Different seeds. Lots of nice beans with no strings
Yep, new is not always good.I don't think we know that for sure. Are you referring to the 12.7 V after charging? That's an indicator, but doesn't really test how strong it is. A better test is with a hydrometer, and the best test is under load.
Well it seems the wiring from the battery to the relay and the realy to the solenoid is ok.
I'm tempted to extract the troubleshooting string out of the chat for future reference....I’ll sum it up, Polaras electrical issues are 98 percent shorted out.
Jumping like this would test the relay's ability - assuming terminal G has a good ground.My gut is to blame the relay, but you could test the feed through the key switch to the S2 terminal.
Ok so making sure I’m following you. Connect the NSS to the battery(check), jump the two terminals above, then turn key to start?Inside the starter relay
Key in start, NSS grounded, the electromagnetic field closes the switch from the Battery to the Solenoid.
I really don't think the connection in the relay can be anything by open or closed. Not sure its possible to have a weak connection due to low current from the key switch o poor ground, but I guess it depends on how its built.
Not quite.Ok so making sure I’m following you. Connect the NSS to the battery(check), jump the two terminals above, then turn key to start?
Probably 6qts there and a couple qts a few days ago we took to my son’s place. LOTS more on the plants. Probably pick again Friday. I need to find the packet. I think they were Ferry Morse ? It’s one row maybe 9ft long. Bugs are thinning the leaves, but so far hardly any bites on the beans. I did put up a jap beetle trap cause they were doing a number on them early.That looks awsome! You did great!
The string beans I grew did well at first after the first harvest, leaves started going white. Bush beans. Going to pull the plants out this week. Maybe today. Had a difficult time with the cukes too.
Love fresh green beans. I boil them to crisp tender, shock them in cold water and wrap 6 or so with a slice of bacon. On the grill they go. When the bacon is done the beans are perfect. No my photo but you get the idea.Probably 6qts there and a couple qts a few days ago we took to my son’s place. LOTS more on the plants. Probably pick again Friday. I need to find the packet. I think they were Ferry Morse ? It’s one row maybe 9ft long. Bugs are thinning the leaves, but so far hardly any bites on the beans. I did put up a jap beetle trap cause they were doing a number on them early.
Everything looks better with bacon.Love fresh green beans. I boil them to crisp tender, shock them in cold water and wrap 6 or so with a slice of bacon. On the grill they go. When the bacon is done the beans are perfect. No my photo but you get the idea.
