That is a roll back trailer....Nice trailer, I have always liked metal deck trailers..... until they are full of snow with a sheet of ice between the deck and your foot. LOL.
The floor hooks are sure handy.
Check this out. You should watch it all but start at 16:05 just for fun.Well Jodi is still traveling so I had to run to grocery to fetch dinner fixings! I did not read nutrition panel as I am guessing serving size is likely two tablespoons or some nonsense. I figure it is healthy, has nuts and dairy!
@Old man ray , great to put a face to the name ....and @65 Dartman a pleasure doing business with you again Don and very grateful for the part as well as the tour of the project car! Love it
Be safe
Don't even go there Chris!1108kg according to the registration
Ze germens vill burn you at ze stake.Don't even go there Chris!![]()
Any party memorabilia in the glove box.1108kg according to the registration
1974 Mercedes 240 CI with only 7084 km on it. My great aunt and her husband in Stugartt Germany bought it new in 74. But lives one block from the train station and 4 blocks from so they rarely drove it. Has every German registration ever in the console, mileage is true.
Dads been extremely protective of it until today. Finally got it out and let my brother and I drive it
I ended up using every trick in book sealing this. I used a steel reinforced one piece gasket. The two spots in front I RTVd with black. Built it up before install. As well as rear sealing surface. Let set up over night. RTV gasket to block. Bolted it on. Let set up overnight. Removed bolts and used RTV to attach pan to block. Making sure to get corners with RTV. Bolted it back on. Now normally I will not use RTV for this gasket. But I was at a loss what else to do.... We will see...Been here before. But it looks like I finely resolved my oil leak. Just started it after the last round of wrenching. Looks dry. So far. I really think it was seeping thru the rear main cap to block. There was zero sealer there from builder. When I replaced the rear seal I sealed it but messed up the gasket install using the wrong type gasket. Really am hoping that is behind me....
I ended up using every trick in book sealing this. I used a steel reinforced one piece gasket. The two spots in front I RTVd with black. Built it up before install. As well as rear sealing surface. Let set up over night. RTV gasket to block. Bolted it on. Let set up overnight. Removed bolts and used RTV to Allah pan to block. Making sure to get corners with RTV. Now normally I will not use RTV for this gasket. But I was at a loss what else to do.... We will see...
Have you seen the saws all blade that cuts brick? And concrete? Wow. Game changer imo.Got several more windows re-caulked. Used the multitool for the repairs I showed earlier. The blade I was using was getting a little dull, but found it worked pretty well cutting loose the old caulk. The more I used it against the bricks, the more it looks like the special caulk removal blade they sell. lol
What are they? How fast do they cut? I used some years ago and they worked, but not fast and not cheep. Had a grit coated edge. Not sure if they were diamond bits or what...Have you seen the saws all blade that cuts brick? And concrete? Wow. Game changer imo.
Something new ....Have to find a link....What are they? How fast do they cut? I used some years ago and they worked, but not fast and not cheep. Had a grit coated edge. Not sure if they were diamond bits or what...
I think these are what I used.
Geez this thread is hard to keep up with.
I leave and 20 million pages go by....
I'm not back reading today, but how's everyone?
Hope you all are comfortable, hopefully no one is surfing fabo from under a bridge or anywhere stinky and uncomfortable...![]()
Only explanation I can think for so few posts would be Hoppy overslept.HAH...
Yeah, this thing rolls like the Mississippi..... Get up in the morning and wonder how you missed 134 posts in 6 hours.
Only explanation I can think for so few posts would be Hoppy overslept.![]()
A bunch of old guys talking like a women's bridge club...HAH...
I have no clue what a women's bridge club talks about.A bunch of old guys talking like a women's bridge club...![]()
