Stop in for a cup of coffee
I think that lettering is harder to read although very similar some of fonts used in ads late 60s early 70s
Maybe if the letter spacing was wider it would read easier.
Swinger reads easily in #2 and that makes the 440DD a bit easier.
I was going for 70s font for sure but ever sense he said it looked more ODD than anything else, I can’t unsee it
If you decide to use a dart, try running it parallel to the bottom of the triangle so it doesn't dominate as it might if shown in perspective.
Every time I see that, I think I should be lookin at a pair of 44dds.
The first one is the most fun to me because of the double entendre is juxtaposed with the corporate lettering.
Wonder about moving the DDs under the 440
I saw the double D and made me think of a girlfriend from long ago...thanks!!
Yes. Try a dot used as a hyphen, then you only need a slight space
Did you say hymen????
If you knew Susie like I knew Susie Oh what a girl!
44 DD's...
