Clean it up, get the bushing off and clean up the shaft with some fine sandpaper, crocus cloth or a scotchbrite pad. There is probably a burr there. You will need a new bushing.Replace then?
Gonna soak it in parts cleaner
Those bushings are pressed into the block and burnished to proper size with a special tool.
Black gunk on your shaft. I hate it when that happens!I'd bet the bushing is still good. I see a lot of black gunk below it. That's why the bushing came out with the shaft. But do inspect closely....
Like this?Now Where is that disagree button ?????????
If they review the first half I don't mind. Watching some lame rapper attempt a halftime show makes me want to lock myself in a closet.<~~~~~ getting practice for disappearing at half time
a few minutes ago. CBS showing these beautiful photos of Pebble Beach and pushing their presence for the PGA tourney next weekend. They obviously haven't looked at a recent weather forecast for Monterey
Yep
Agreed!That feeling when after a break of several months, you're double checking the front suspension and validate that you did, in fact, install the torsion bars on the correct sides...
Does it slip on the shaft smoothly? It will get slightly tighter when it goes back in the block.Seems none the worse for wear... as they say
It is official Jackson had his trademark meltdown, helmet swinging toss and all. Chiefs are renting space in his head.
Better than filling his pants!Yes... slides easily....
Karl is gonna fill pages
Time is running out. Nice field goal. Can KC run out the clock ?Tic tic tic
