Looks yummyCreamy shrimp pasta with mushrooms tonight. Not too fancy looking but it sure is delicious.
AlmostCreamy shrimp pasta with mushrooms tonight. Not too fancy looking but it sure is delicious.
Hmmm what did you do to the thing again? Just an intake?I felt the load increase on the drill (Karl)... and I have 89 psi at the oil pressure port on top of the engine. Just don't have oil at the rockers
I was thinking somehting like that might be a way to do it.I grind the od of old race and use it as a driver.i have an assortment of them. Safety glasses.
Intake and new oil pump/ pickup.Hmmm what did you do to the thing again? Just an intake?
Well, the oil.pump and pick up are working or you wouldn't have oil pressure. The intake doesn't have oil running through it so that's not an issue.Intake and new oil pump/ pickup.
Timing Chain and cover
Water pump
Fuel pump
Take off.![]()
Have a safe trip.Take off.![]()
Got it.Well, the oil.pump and pick up are working or you wouldn't have oil pressure. The intake doesn't have oil running through it so that's not an issue.
Possibly. Curious to see what you find outI believe it was how I was going about it, not a mechanical issue
Yay!!
Good to see
Kitty litterOil all over the floor, but in this case, I'm happy about it.
Kitty litter
YepSooooo....
I'm screwed with timing marks with the early timing chain cover, aren't I?
Different HB required?
Rookie mistake I think
My brother goes up to Canaan often
So, your looking at a junkyard?
Little hiccup to fix, but progress nonethelessGlad you figured it out Chris.
