Stop in for a cup of coffee
Did you check the plugs. Rich or lean?
Not big enough for a stroker. I have a 650 afb on my 273. I would say a 750 would make it happy or jet up the one you have. Give that a whirl.
Might be on to something.....Going to order jet kit. I really want to squeeze as much MPG as I can out of this. Hence, the 570.....I know just pay for the fuel. BUT 5.60 a gallon here for premium...
Got my starter. Was not expecting this… They only showed the other side. Must have been a late change, cause every one I’ve seen had 2 studs. Anyone know if this just an adapter held by the nut or hard wired in? Could it be that simple and have a stud under it? Or will I F it up if I try to remove the quick connect? I can probably find a connector pigtail , but would prefer to nut it on like the older ones.
Sorry, not seen that B4
The Holley you had on it from me is a 750.
What an akward place to smear filler. Never had such a problem. I guess its the narrow areas and cramped area to work. Sometimes i wish i had a seat in the cab. Not done with filler, but primed it to find the highs and lows. Too ugly for a photo at this time.
Finger sanding sucks.
