@Mattax Rhetorical question, Why do people rewire their car, mess it up, and then ask for help straightening it out?![]()
www.forabodiesonly.com
I pledge to never help another follower of MAD
I pledge to never help another MAD follower
I have to be nuts to help another crazy MAD disaster
Sounds like you're serious about that.
Just marking it's spot.Think I leak worse than my car but not as bad as the 29 truck. It pisses all over the garage floor.
Yep. I figure do it document it with pictures, then post it when it works. Sure there will always be a few Negative Nancy's. I would have done it this way.You are a smart man. If you open questions up to the masses you will get so many answers and there's a good chance most will lead you in the wrong direction.
3.375 stroke, mine was offset ground for another. 0014 with a 4.310 bore.What is the stroke/bore of a 383? i could google.. but...
Don't think I have seen a Jungle Jim car with a HEMI in it, just big block Chevy's.
That's no air guitar. He is wrestling with the invisible Woman.Toolmanmike usually has his guitar with….
Ok where is the hemi?
Stand corrected.
That cars got points
Thats like buying a box of condoms and all you received is the packaging.Hayden fan clutch showed up... man that thing is tight, i'm sure it will loosen.. what's funny is they put a bag with 4 lock washers in with it.. but no bolts
still works.... but you will get complaintsThats like buying a box of condoms and all you received is the packaging.
I sure hope so.If not,send it back. I put a "stock replacement" clutch on my Dakota and the damn thing never was loose when cold. Leave the house and it sounded like a B52 going up the street for 15 min or so.Hayden fan clutch showed up... man that thing is tight, i'm sure it will loosen.. what's funny is they put a bag with 4 lock washers in with it.. but no bolts
My world!
I dunno!
Someone told 'em was not only a good idea, but would be an upgrade.
Well actually they read it in a magazine
or saw it on the internet
facebook?
Youtube?
OK. Here's a related question.
Why do people buy a wire kit, or an ignition, or really anything from a well known company, and then come here to ask how to install it?
1974 Dart 318 crank, but no start (Solved)
***SOLVED*** Wire from ICM/ECU to Negative side of coil was broken right at crimp, but rubber sleeve held it in place without allowing voltage to pass thru. I know this issue has been beat to death, I've read the posts, watched the videos, and I'm still stumped. 1974 Dart, 318 w/electronic...www.forabodiesonly.com
www.forbbodiesonly.com
Are you talking about FABO or the weather?A lot of wind here today.........................I hate the wind we have too many trees.![]()
