That sucksCrap. I think I missed out on drag racing and road racing events on powertour. Needed to pre register. Did not kmow...grrr
Did not see any mention of having to pre register.That blows, big time
What do you show and how does it shine?Weather is iffy for the Show and Shine tonight.![]()
Is it to late.Did not see any mention of having to pre register.
And I spent 400 on a approved helmet. Could have saved the moneyThat sucks
Wait list onlyIs it to late.
I was really looking forward to the road courseIs it to late.
Still have a shot then, still sucks.Wait list only
Do you someone special to polish it .What do you show and how does it shine?
Looking forward to seeing it at MITP.Should be able to fire it back up later today with a little luck. Just needs plugs, Engine oil, trans fluid, brakes bled, driveshaft and new starter relay because the ground terminal threads stripped out. I also ordered a distributor curve kit from FBO Ignitions that should be here tomorrow, hopefully. My gear vendors overdrive should be arriving in the next week or two. I'll tackle that project after Mopars In The Park.
More fresh-ground coffee should help to get me through.
Cheers!
That could be a 500 helmet at the last minute along the wayAnd I spent 400 on a approved helmet. Could have saved the money
Beautiful.......Should be able to fire it back up later today with a little luck. Just needs plugs, Engine oil, trans fluid, brakes bled, driveshaft and new starter relay because the ground terminal threads stripped out. I also ordered a distributor curve kit from FBO Ignitions that should be here tomorrow, hopefully. My gear vendors overdrive should be arriving in the next week or two. I'll tackle that project after Mopars In The Park.
Cheers!
Get a bigger stereoMufflers showed up finally... a bit smaller than i expected... this is gonna be too loud prolly..
What did you go with?Mufflers showed up finally... a bit smaller than i expected... this is gonna be too loud prolly..
That's good to hear. I'm excited to see the difference and have more rearend gear choices once the overdrive is in!Looking forward to seeing it at MITP.
Running a Gear Vendor in my Scamp and really like it.
Gibson MWA mufflers.. doing 3" out the backWhat did you go with?
Thanks, Mitch!Beautiful.......
What gear do you run now?That's good to hear. I'm excited to see the difference and have more rearend gear choices once the overdrive is in!
I'll take you for a drive so you can see. Was running 4:11 but switched to 3:23 for my long trip last year. 80 MPH no problem with 3:23's. Think if I remember right, from 3:23 in overdrive was 2:53'sThat's good to hear. I'm excited to see the difference and have more rearend gear choices once the overdrive is in!
I'll take ya up on that!I'll take you for a drive so you can see. Was running 4:11 but switched to 3:23 for my long trip last year. 80 MPH no problem with 3:23's. Think if I remember right, from 3:23 in overdrive was 2:53's
right now I have 3.73s but I'm also building a 4.56 and a 4.10 center section. Options! The 4.56 will drop to a 3.54 in overdrive and the 4.10 will drop to 3.20. I think the 4.10 will be my main choice.What gear do you run now?
2.71 I think with 3.23 and GVI'll take you for a drive so you can see. Was running 4:11 but switched to 3:23 for my long trip last year. 80 MPH no problem with 3:23's. Think if I remember right, from 3:23 in overdrive was 2:53's
